Chevy/GMC Heavy Duty Discuss your 2500 and 3500 Chevy and GMC pickups as well as the DURAMAX diesel and it's predecessors
8.1L 'Check Engine' + 'Reduced Power' dash lights.
Old Jan 27, 2022 | 12:08 PM
Socal8's Avatar
Default 8.1L 'Check Engine' + 'Reduced Power' dash lights.
Ok...everyone. Here's one that's stumping me. Before, I describe, know that I've already thrown a good amount money in repairs and new parts at this problem.
So, my issue is the truck running fine and out of nowhere lights up the dashboard with both the 'Check Engine' plus 'Reduce Power' lights. And, does go into a reduced power mode. Along with running real rough.
Initially, it was giving Throttle Body type error codes. Which had ne change out the TPS three different times. And, the actual Throttle Body twice. Plus, I changed out the Pig Tail part of the wiring, as well.
No success!
Then, after some research, I started replacing air intake parts.Air Filter, MAF Sensor.
Still no succes!
The interesting thing about this problem is that it seems to happen much more frequently during cold weather. Like 40s and below???
Anyway, looking forward to suggestions !
Socal8
'02, 2500HD, 8.1L, 4x4, Allison, crew cab, LS
Socal8
Jan 24, 2022 05:02 PM
Socal8
Jan 22, 2022 05:10 PM
Doug D
Jul 23, 2011 05:27 PM
jumpinfarmer
Nov 8, 2008 09:11 PM
alexmolinavr6
Oct 6, 2008 05:53 PM
