Fuel Temperature Sensor - Voltage Above Normal
#Troubleshooting:
The troubleshooting procedures for the diagnostic codes of each temperature sensor are identical. The temperature sensors are passive sensors that have two terminals. The temperature sensors do not require supply voltage from the Electronic Control Module (ECM). Test Step 1. Inspect Electrical Connectors and Wiring A. Turn the keyswitch to the OFF position. B. Thoroughly inspect ECM connectors and the connector for Fuel Temperature Sensor. C. Perform a 45 N (10 lb) pull test on each of the wires in the sensor connector and the ECM connector that are associated with the active diagnostic code. D. Verify that the latch tab of the connector is properly latched. E. Check the allen head screw on the ECM connectors for the proper torque. F. Check the harness and wiring for abrasions and for pinch points from the sensor to the ECM. Expected Result: All connectors, pins, and sockets are completely coupled and/or inserted. The harness and wiring are free of corrosion, of abrasion, and of pinch points. Test Step 2. Check for Active Diagnostic Codes A. Connect Caterpillar Electronic Technician (ET) to the service tool connector. B. Turn the keyswitch to the ON position. C. Check for active diagnostic codes CAT ET. Record any active diagnostic codes. Note: Wait at least 15 seconds in order for the diagnostic codes to become active. D. Determine if the problem is related to an open circuit diagnostic code -03 or a short circuit diagnostic code -04. Test Step 3. Check the Pull-Up Voltage at the Sensor Connector A. Disconnect the Fuel Temperature Sensor connector. B. Turn the keyswitch to the ON position. C. Measure the voltage between terminal 1 (sensor signal) and terminal 2 (sensor return) at the sensor connector. D. Turn the keyswitch to the OFF position. Expected Result: The voltage is 5.5 ± 0.5 VDC. Test Step 4. Create a Short at the Suspect Sensor Connector A. Turn the keyswitch to the OFF position. B. Install a jumper wire between terminal 1 and terminal 2 on the connector for the suspect sensor. C. Connect the jumper on the harness side of the connector. D. Turn the keyswitch to the ON position. E. Check for active diagnostic codes Cat ET. Record any active diagnostic codes. Wait at least 15 seconds for activation of the short circuit diagnostic code -04. F. Remove the jumper wire. G. Turn the keyswitch to the OFF position. Expected Result: A short circuit diagnostic code -04 is active when the jumper wire is installed. An open circuit diagnostic code -03 is active when the jumper wire is removed. OK - The engine harness and the ECM are OK. Repair - Temporarily connect a new sensor to the harness, but do not install the new sensor in the engine. Verify that there are no Active Diagnostic Codes for the sensor. If there are no Active Diagnostic Codes for the sensor, permanently install the new sensor (CAT P/N: 197-8391). Clear any logged diagnostic codes. If you have any other questions, Email: Sales@obd2.ltd |
| All times are GMT -5. The time now is 12:52 AM. |
