-   Chevy/GMC Heavy Duty (https://www.truckforums.com/forum/chevy-gmc-heavy-duty-102/)
-   -   NEED HELP 97 chevy 6.5 diesel (https://www.truckforums.com/forum/chevy-gmc-heavy-duty-102/need-help-97-chevy-6-5-diesel-18642/)
manny83107 Apr 15, 2012 09:20 PM
I have a 97 Chevy cheyenne 3500 6.5 diesel, was working fine. when i went to start, no power to glow plugs, electric pump or injector pump. any ideas? i already checked the fuses and relays as well as the connections.
Diesel Dan Apr 15, 2012 09:26 PM
Did you use a test light to check all the fuses?
Sounds like you lost power to some circuits. Check battery connections and fuse links to start. Trying to recall if a failed ignition switch will cut power to those circuits.
