-   Chevy/GMC Heavy Duty (https://www.truckforums.com/forum/chevy-gmc-heavy-duty-102/)
-   -   vacuum pump pulley removal (https://www.truckforums.com/forum/chevy-gmc-heavy-duty-102/vacuum-pump-pulley-removal-14075/)
woodchuckvermonter Jun 30, 2010 01:29 PM
Does anyone know how to remove the vacuum pump pulley from the pump itself? I need to replace the pump and have it, but can't figure out how to remove the pulley from the old shaft. Thanks, Woodchuck
Mr.Cale Nov 8, 2010 09:48 PM
Hello,
Need a little more info like the year and the motor ect.
delta Jan 9, 2011 02:30 AM
It can't figure out how to remove the pulley from the old shaft.
Thanks!
________
thai property in Pattaya
Mr.Cale Jan 10, 2011 08:41 PM
Alright, You will need a puller most likely you can get one from autoZone or napa or what have you that will do the job you can usually rent them
nelsee Aug 8, 2012 01:22 AM
You can call out the mechanic and clear out the isssue it would be better.
