2000 brake problem
so i got a 2000 s10 4x4 and i am having a problem with my ABS. almost everytime i pull into a parking space or brake while going really slow my ABS kicks in and starts pushing the brakes back at me and i cant stop. i just changed out my rotors, calipiers, pads and hoses on all 4. anyone have any ideas? thanks
RE: 2000 brake problem
most likely,one of the abs sensors is faulty,telling the ebcm that it's sliding when it is not....thats the usual reason...i've seen a few other things,like a cracked teethed ring that the sensor reads
so where would i find this sensor and how can i check it?
each front wheel has itsown abs sensor...most older trucks have 1 for the rears...the brake copmputer monitors these wheel speeds closely...if 1 slows dramaticaly ahead of the others,the module takes action and kicks in abs...but 1 can "lie" and send false values to the pooter..
you check em with an volt meter to see if they work...but you'll have to have a scanner capable of freeze framing the speeds to catch it |
