2002 s-10
fuel pump wood not run with ignition turn on, replaced fuse, same thing. Install new GM fuel pump, still doesn't work. Any suggestions.........
RE: 2002 s-10
Key on, check at the pump for power. Check wiring harness for possible broken/cut wires or dirty connections. (it happens) Also check for good ground. note: Just because it's a new pump, it doesn't necessarily mean it works.
Let us know what you find, Brad |
| All times are GMT -5. The time now is 09:43 AM. |
