2007 gmc canyon problems
Just wondering if anybody has had any problems with there 2007 gmc crew cab canyon,I,ve had a couple and just wondering if anyone else has had the same problems,One problem is a creaky dash board,sometimes its on the left side and different times its on the right,just seems mainly when its cool out,the other one is my fan,it seems to make a ticking noise,thrird one is inner tire wear,just wondering if these problems are common with other canyon drivers...this inner tire wear is coming from the front...2007
What kind of pressure are you running and how often do you get your tires rotated/balanced?
My tire pressure is exactly what it says on the side of the door and I rotate my tires every 8000 km,had some kind of an alignment done 7 mionths ago cause my tires were starting to wear in the inner wall again,now 7 months later its doing it again,,go figure,,
If I were you I would pump up the front tires about 5-7psi more. The only time I have ever had a truck wear the inside fronts was when my mom drove my 89 about 20 miles on dry pavement in 4wd
hey erber,
just bought a '05 canyon crewcab and i have that same ticking noise coming from my fan - just wondering, did you ever figure out what it was and/or fix it? thanks, jtg |
