-   Chevy/GMC Small Trucks Forum (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/)
-   -   96 chevy s 10 engine light (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/96-chevy-s-10-engine-light-12718/)
chevymatt96 Feb 1, 2010 03:37 PM
my check engine light came on so i went down to to auto parts store and the told me what the problem was so i bought the parts and fixed it but now the light is stuck on and i have emissions soon and if its on it wont pass, is there anthing i can do to manually shut the light off?
bchristy Apr 27, 2010 08:37 PM
you can turn off your engine light by disconnecting the battery on the truck and then pumping the brake pedal 3 to 4 times. i cant remember which. this worked for me on my 96 sonoma. apparently it also works on many other GM vehicles.
Mr_Shamrock Apr 27, 2010 09:13 PM
You don't have to pump the brake. Just disconnect the negative terminal from the battery for about a minute or so. That resets the ECM, but if you still have an issue the light will come back on.
Worf Apr 28, 2010 04:36 AM
what was the code that caused the light to come on ?
