-   Chevy/GMC Small Trucks Forum (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/)
-   -   coil (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/coil-7007/)
donkeydan Apr 22, 2008 05:23 PM
coil
anyone know how to test the ignition coils on a 02 s-10 with a 2.2? My mileage has been terrible lately and every now and then it cuts out. I have changed wires, plugs and fuel filter. thanks
rxsteven Apr 22, 2008 07:05 PM
RE: coil
Auto Zone will check it for you.
donkeydan Apr 23, 2008 04:31 PM
RE: coil
any idea how they test it? I checked the primary and seconday resistance and they where in spec. My friend is a mechanic and says he hasnt had any luck testing them that way.
EvansBlue Apr 25, 2008 08:24 AM
RE: coil
Have you had the codes run on the vehicle? With those 2.2l engines, the O2 sensors are notorious for fouling and the PCV valves have a tendency to regurgitate oil if they ever lose vacuum.
Take your intake off and inspect it for oil, and take it to auto zone and get them to run the codes on it.
donkeydan Apr 27, 2008 08:16 AM
RE: coil
Well I haven't had any codes, and I replaced the o2 sensors. I'm not sure where else to go besides the coils.
EvansBlue Apr 27, 2008 08:45 PM
RE: coil
Have you considered the possibility that the injectors are stopped up?
rxsteven Apr 27, 2008 11:20 PM
RE: coil
When it dies dose it choke then die or just cut out?
donkeydan Apr 28, 2008 04:17 PM
RE: coil
Ive had the injectors cleaned and it just cuts out sometimes going down the highway, usually when its warm and has a good load on it like going uphill. It feels a little down on power and mileage is down a few miles.
