fuel pressure
Does anyone know what the fuel pressure should be on a 02 s-10 with a 2.2 flex fuel 4 cylinder? thanks
RE: fuel pressure
i'll have to look it up to be sure,,,but around 43
RE: fuel pressure
thanks argon
RE: fuel pressure
a buddy cleaned my injectors the other day and it read over a 100 on his gage, and we knew that couldnt be right.
RE: fuel pressure
yeah,his gauge had to be nuts..the fuel would rocket thru the injectors with 100 psi
RE: fuel pressure
well the bad thing is he hooked up another gauge he had and it registered the same. any suggestions?
RE: fuel pressure
Argon help!
RE: fuel pressure
bump
RE: fuel pressure
WOW.wayy too high...the first thing to look for is a return line kinked..llook underneath at the lines./.if the return is kinked,the pressure will go up
RE: fuel pressure
i looked it up to make sure..its 56 psi
