p 0151 k1500 1997
I have a p0151 code that wont go away here is a list of stuff iv done and stats I have on bank 2
spider injector swapped mass air no exhaust leak No vacuum leak no intake leaks new gm, plugs,cap ,rotor,wire new #1 o2 sensor 170 psi compression on all 4 cylinders 60 psi fuel pressure with key on new pcm I ohm bank 2, it has same reading as bank 1 shrt term fuel trim 50% long term fuel trim at 11.7 % truck runs fine at operating speed,when I come to a stop after 15 sec the idle gets rough and it runs rich. I have a hard time thinking I got a bad fuel filter or fuel pump,because its only on band 2..any ideas would be great.. |
| All times are GMT -5. The time now is 02:24 AM. |
