-   -   00 silverado gas gauge (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/00-silverado-gas-gauge-2273/)
lakerunner696 Dec 30, 2006 07:53 PM
my gas gauge bounces from full to empty and the message center "low fuel" light comes on even when tank is full. I was told it was expensive and required replacing a whole cluster to the gauges I assume.Can it be fixed easy and without alot of expense.I heard this is a common problem
under construction Dec 31, 2006 03:30 AM
RE: 00 silverado gas gauge
mine does that only when its time to fill up...when it only has a 1/4 tank left, i just figured it was the sending unit but i never really checked.
00_slammmed Jan 1, 2007 04:38 PM
it is not likelythe gauge cluster it is usuallythe two metal prongs on the resistor for the floaton the fuel pumpi see this problem fairly often they wear through and make contact only every now and then that is why the gauge tends to bounce i also had the samr problem on my truck i just took theprongs off ablazer fuel pump we had laying in the shop
sc64chevy Jan 2, 2007 07:52 PM
You can also try to put some Lucas fuel injection cleaner in the tank cause sometimes the contacts get gummed up and that will clean them.
gm trucker Feb 27, 2007 10:23 PM
This is becoming somewhat common. Last post is right on! It's the float sticking. Fuel injector cleaner, max. strengh about quarter tank.
I've had luck doing hard stop and accel. to move the float around.
It's almost always the float.
Good luck
scdeerhunter Mar 3, 2007 01:21 PM
it is the sending unit
