-   -   02 avalanche 8.1 vort. having problems with my fuel gauge (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/02-avalanche-8-1-vort-having-problems-my-fuel-gauge-19107/)
02avalanche Oct 6, 2012 08:55 PM
can anyone tell me why my low fuel light keeps coming on and the gauge is reading Empty.. it wil flicker for a moment when i start my truck up to show the correct amount of fuel but will drop right back down to empty.. if i fill the tank all the way up ( which sucks having a 37 gallon tank) it seems like the float or what ever will unstick so i think and it will read the gauge will read right. but if i gets down to about a quarter tank i will have to be careful cause it will read empty real fast again even with fuel in it... i have a half a tank now and it is still reading empty. i have checked the fuse and relay and still same problem..... is it my fuel pump???? please help:eek:
acnas Oct 7, 2012 08:02 PM
Fuel level sensor
02avalanche Oct 8, 2012 12:23 PM
does it sit on top of my tank or do i have to end up replacing the fuel pump?? do yuh now?? i guess i could call the a dealership and find out but if yuh know that would be helpful.. and thanks
acnas Oct 8, 2012 05:04 PM
You can just get the sensor from the dealer. If it has alot of miles you may want to do the pump/assembly. It mounts on the pump/sender.
Gator68 Oct 17, 2012 08:24 AM
Sending unit on the pump, and its in the tank, I pretty sure you have to change the whole thing, my 01 tahoe has been doing that for a while, just can't let go of 300 bucks right now. By the way, thinking of trading my 03 6.0 silverado for a 01 same truck is mine, with the 8.1 in it. Are you happy with your setup and what kind of mpg's do you get, thanks.
