'02 silverado v8 vortec ext cab 4x4
Hi der just bought this 02 wit 141k kilometres. Brake problem. press brake pedal seems to go lower than it shud, if pressed really hard there is grinding noise towards the end of play, a sudden resistance then then after that brakes apply again. Observation: while i was pulling into parking lot and went to stop, the pedal met this resistanc, (grinding ) there is loss of braking at this point till the pedal gets thru this resistance spot. Its only there at the bottom of play. pedal seems to go lower than it should. The res is 1/2 full. Havent pulled the wheels yet. Any comments wud be appreciated. Thanks
Done brake job, rotors were bad. Brakes pedal up now, same problem. Drove out into field wit new brakse,then the prob started again. noisy grinding during pedal play, momentary loss of brakes till pedal is forced thru the rough spot. Upward pulsing pressure on pedal as its being forced down thru grinding spot. Hope this helps, thanks. No ABS lite showing on dash when running.
FinishLineAutoWorks
Dec 16, 2008 03:24 AM
FinishLineAutoWorks
Vehicles for Sale
Dec 15, 2008 06:06 PM
