-   -   03 Silverado 1500 CEL (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/03-silverado-1500-cel-9005/)
Fox Jan 30, 2009 09:51 AM
pulled the code for the CEL and i think it was P0172 and P0174.. both meaning that it is lean in banks 1 and bank 2. This problem has come up befor, about 3 months ago, we checked the fuel pressure, new fuel pump,. EVerything. finally took it to the dealer, said fix this. They cleaned out the TB. and it ran perfect.. a few weeks ago, security forces took the truck for a trip.. (roughly a 2-3 hour round trip.) CEl poped up again, same code. sprayed TB cleaner in...and no more CEL....what could be the cause of this? is there something we need to do so we dont have to keep cleaning the TB every time the truck hits 3 hours of opperation? Thanks for alll the help guys.
ahcapone Jan 30, 2009 12:37 PM
RE: 03 Silverado 1500 CEL
I would normally assume that it was a bad 02 sensor but with both banks showing the same problem I'm not sure.
Fox Feb 3, 2009 02:43 PM
if it was a Bad o2. wouldnt it come up as a bad o2 sensor as the code? or atleast throw more codes? ie. lean both banks, and bad o2. i will def check that out tho! thanks for the heads up ill tell my sargent
acnas Feb 3, 2009 05:13 PM
Possible intake/gaskets. I know they have updated intake gaskets for these codes. Possible warped intake as well. Just something to look into.
