'04 1500 w/ 5.3
About three weeks ago I chanced the plugs and did a low pressure rinse to get some of the dust off the motor. While I was changing plugs I had the battery disconnected to reset the puter. After I finished and within two days I got a check engine light. Took it by Advance and they read a P0332 Knock Sensor bank 2 I think.
What do you think I should check and if it is the knock sensor can you tell me where it is located on the engine?
I unplugged a small sensor behind the power steering pump when I was changing plugs but it is plugged in now.
What's the word?
Steve
What's the word?
Steve
Those knock sensors are notorious for that. There are 2 under the intake and usually it is the rear that gets flooded and triggers the check engine light. If you do need to swap them I would replace both while your there. Let us know if you decide to b/c there are a few things you should know about the repair.
Ok please fill me in on what I need to know since I will probably need to change them out. Does the water actually damage the knock sensor?
Steve
Steve
adampgasser
Jan 31, 2008 10:17 AM
