05 GMC Sierra
A failing power steering pump usually doesn't cause play in the steering wheel. The pump helps with steering effort, but play in the wheel is more often caused by worn steering components like the tie rods, steering box, or ball joints. You might want to check those parts to see if they’re causing the issue. If the steering feels hard or you hear noises when turning, that could be related to the pump.
Brock05
Mar 1, 2024 10:33 AM
BawFaw
Dec 2, 2007 07:52 PM
