100k tune up
Hi, I've had my 99 silverado 5.3L ext cab for about a year now and i just hit 100k miles. What are some things that I should be looking at or replacing? plugs, o2 sensors, etc? I'm already getting a thermostat and k&N filter. Any thoughts are greatly appreciated
Fuel filter,plugs wires but i would pull a plug or two and look at them mine looked brand new so i left them.Clean the carbon off the trottle body blade and inlet,helps idle greatly.Injector cleaner.
Here's what Autozone says you should be doing. I started with 75k just catch up:
75000 miles or 120000 kilometers Oil Filter, Engine Engine Oil Cabin Air Filter Brakes and Traction Control Inspect Fluid - Differential Inspect Tires Rotate 82500 miles or 132000 kilometers Oil Filter, Engine Engine Oil Brakes and Traction Control Inspect Fluid - Differential Inspect Tires Rotate 90000 miles or 144000 kilometers Fuel Filter Oil Filter, Engine Engine Oil Cabin Air Filter Brakes and Traction Control Inspect Fluid - Differential Inspect Tires Rotate 97500 miles or 156000 kilometers Oil Filter, Engine Engine Oil Brakes and Traction Control Inspect Fluid - Differential Inspect Tires Rotate 100000 miles or 160000 kilometers Spark Plug Fluid Filter - A/T Fluid - A/T Positive Crankcase Ventilation Valve Inspect Ignition Cable Inspect |
