1987 pops and bangs
my 87 GMC K2500, 350 engine runs good for a bit and then it starts popping, banging and farting thru the carb. I have had it at the local GM dealer ship and spent $856 so far and it still runs like Sh!!t. replaced the dis cap set the timing, checked what few sensors there are on it, checked vacuum hoses and routing and now I am lost. anyone got any ideas?
For sure it is timing goin off. The timing gears were made of nylon from the factory and so the teeth would become very weak after so many miles. Even the distributor gear had the same problem. I would look at those.
Originally Posted by bikernut
(Post 63117)
checking around I found a ground wire behind the engine that was loose on the engine as well as the firewall tightened both and the popping and banging went away. I was so happy I could again plow snow from my driveway I had at it and destroyed the inner axle shaft on the left side so back into the garage for repair. Thanks everyone for the help.
Glad you got it fixed! Jus for assurance, I would add another grounding cable. I have done this to all my vehicles.
| All times are GMT -5. The time now is 08:58 AM. |
