1988 electronic odometer problem
Old Oct 7, 2013 | 12:03 PM
dansvs's Avatar
Default 1988 electronic odometer problem
I have an 88 silverado ext cab that the odometer will only register if you are at highway speeds. Speed registers normally on the speedo at all speeds. I repaired a cracked gear from the motor which drives the odometer after it stopped registering altogether last year. Don't know what to look for or how to test any further. Changed the speed sensor because trans fluid was leaking out of it but still no miles at lower speeds.
Thanks for any help.
Dan
Old Oct 7, 2013 | 01:47 PM
TMW's Avatar
TMW
Maybe the motor is bad.
Old Oct 7, 2013 | 05:59 PM
dansvs's Avatar
Would you know what voltage to apply to motor to check it?
12volts? Or other and on which terminal?
I can't find a full schematic to trace it to see if it flows through some transducer or relay
Old Oct 7, 2013 | 06:22 PM
TMW's Avatar
TMW
I don't know the voltage. It may be easier to replace the motor or cluster with one from a junkyard.
Six5
Aug 27, 2019 09:39 AM
uhcoog1
Oct 29, 2010 10:10 AM
PLussier
Aug 14, 2010 07:53 AM
saltron
Sep 12, 2009 07:45 PM
gronotte
Jan 11, 2008 11:34 PM
