1993 GMC 1500 Problem!
Old Aug 15, 2007 | 09:02 PM
iamthepolarbear's Avatar
Default 1993 GMC 1500 Problem!
Greetings!
Well... I have a real problem thatI just can't seem to fix... so any help that you guys could give would be great! Here are the specs:
1993 GMC 1500 4x4, SLE, 5.7 V8, Auto, 73,000, Full Power
I recentlybought a used truck. According to the owner it had been sitting for about a month, and ran fine during the test drive. So... I bought it!It was running just fine, until it started to run a little rough at idle or really slow speeds. As I was continuing home, the problem got worse. It got to the point were I had to press the brake and the gas down at the same time at stoplights. Got it home, and the first thing I did was check the OBD codes. It told me that it wasn't recieving any signal from the speed sensor. So I replaced it to no avail, and the code still remained. The engine will try to crank over, and will start up for a brief second, and then die. So I thought that it might be a fuel problem, so I replaced the fuel filter which wasn't great, but seemed to have no change. So now I don't have a clue as where else to proceed, but hopfully someone can help.
Old Aug 16, 2007 | 04:41 AM
Argon's Avatar
Default RE: 1993 GMC 1500 Problem!
is it a "rythym" miss...or random?...something like a plug wire will miss on time.
will it go if you stomp the pedal hard?
Also,check the egr,,those years were bad about the valve hanging up....it will only run rough @idle
Old Aug 16, 2007 | 05:36 PM
It doesn't seem to be rythym miss, and it used to be that it would go if you stomped on the pedel. Now... I can't even get it started. It will turn over, but that is about it. When I get a chance I will check on that EGR.
Old Aug 21, 2007 | 05:52 PM
oif4vet's Avatar
Try pulling the oxygen sensor. If it works then your CAT is clogged.
Old Aug 31, 2007 | 11:34 AM
stopspazinout's Avatar
have you pulled the distributor cap and looked at the cap and rotor?
Jeremy5756
12
Mar 11, 2015 10:07 PM
smr1968
Dec 31, 2011 03:22 PM
aclt765
Apr 12, 2010 07:26 PM
mcivilsurveyor
Aug 19, 2009 11:11 AM
codys
Jul 23, 2008 05:10 PM
