1995 Chevy Silverado 5.7l doesn't have spark
Old Feb 10, 2011 | 06:48 AM
  #11
When you set the timing did you unplug the electronic advance wire?
Old Feb 10, 2011 | 10:19 AM
  #12
chevychase's Avatar
That would be the coolant temp sensor , located beside thermostat housing.
Clean those grounds in that are while your at it.
Old Feb 10, 2011 | 10:22 AM
  #13
Worf's Avatar
Have you checked your fuel pressure? How old is the air filter? And fuel filter?
Old Feb 10, 2011 | 10:32 AM
  #14
RUFFNECK4LYFE's Avatar
Maybe the throttle body could be leaking causing the hissing? A vacum leak will cause bad hesitation on acceleration on the low end.
Old Feb 10, 2011 | 10:34 AM
  #15
Worf's Avatar
This is true
Old Feb 10, 2011 | 10:48 AM
  #16
chevychase's Avatar
The hissing is starving for fuel , more air than fuel.
Old Feb 10, 2011 | 12:29 PM
  #17
fstcarsnguitars's Avatar
This is what I'm thinking it definitely sounds related to the TBI. Possibly an injector leaking? (bad o ring?) I haven't checked the fuel pressure but the air and fuel filter are brand new. I will also clean the temp sensor terminals.
Shamrock, I did not unplug the advance wire when i set the timing.
Also, I've noticed the RPM'S dropped at idle and sit at about 800 now
Old Feb 10, 2011 | 06:52 PM
  #18
Shamrock knows those TBI set ups pretty good. I have heard them leak from the flaps or base, I cant remember.
Old Feb 10, 2011 | 08:45 PM
  #19
The injectors have a sort of "spattery sound to them and almost like a constant clicking, like a diesel motor. Is this normal?
Old Feb 10, 2011 | 08:49 PM
  #20
chrisbmo2000's Avatar
yes that is normal the click is the injector opening and closing and the other sound is the fuel spraying out......sound like they are working but I would run some cleaner through just because. never hurts to be safe and clean them
