Originally Posted by chrisbmo2000
(Post 64053)
yes that is normal the click is the injector opening and closing and the other sound is the fuel spraying out......sound like they are working but I would run some cleaner through just because. never hurts to be safe and clean them
Originally Posted by Mr_Shamrock
(Post 63993)
When you set the timing did you unplug the electronic advance wire?
Problem Solved. Thanks Everyone! |
Come on buddy post up the solution. Maybe in the future someone else with the same problem could use this as reference.
well that's why i quoted shamrock. The problem was that the electronic advance was not disconnected when I originally did the timing...boy do I feel dumb haha. Once I disconnected it, loosened the distributor, got the timing light and reset the timing back to where i wanted it. After that I turned off the truck, reconnected the wire and fired it up..sure enough it runs beautiful now!
Ahh dont feel bad, I did the exact same thing with my 92 Iroc. Glad you got her fixed!
Thanks Everyone for all the help!:D
The hissing sound ... starving for fuel. Get the coolant temp sensor out of the ..equation.
Beside thermostat housing.. clean the grounds in that are also. |
i have same problem
i replaced alternater ,coil,plug wires,dist cap , module,and computer. after everyone of those the truck would start i would run it 30 min. and then it would not restart the last one was the computer it started i drove it 5 miles.the tranny started slipping it never slipped b4 that time shut it off sunday and it will not start again and there is no spark again. im stummped cAN ANYBODY HELP!!!!! thanks its a silverado 4by4 1500 extended cab 1995
