| Mukilteo |
Jul 25, 2012 10:23 PM |
Is the clutch on the Compressor engaging?
Open the hood and look at the A/C compressor; notice that part if it is a clutch and the rest of it is kinda like a flywheel the clutch engages the A/C compressor shaft to. The outer part spins with the belt, but part of it doesn't when the A/C is off. Have someone start the engine with the A/C off, then tell them to turn it on. You should hear the clutch on the front of the compressor engage and notice that before only part of the pulley was spinning and now the whole thing is spinning. It will usually cycle in and out, sometimes more often than others. The key is that the compressor needs to engage...if it isn't, that's your problem.
