-   -   1996 seirra brakes (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/1996-seirra-brakes-4605/)
Bruce Sep 24, 2007 02:08 PM
1996 seirra brakes
I replaced front rotors on my truck. After about three months they started to pulse when I would come to a stop. I took them back, and got a new pair. Now they'er starting to pulse again. I pulled my back drums thinking that maybe the front was doing all the breaking. The back shoes look good. Anybody have any ideas? Thanks Bruce
Argon Sep 24, 2007 03:37 PM
RE: 1996 seirra brakes
the rotors may be getting warped due to over-tightening....
machine those,or get a new pair,and torque em in sequence to spec
Bruce Sep 25, 2007 02:12 PM
Argon, Can you explain "tightening seqence and specs". The rotors on my truck tighten up when I tighten the wheels with the lug nuts. Am I missing something? Bruce
stopspazinout Sep 30, 2007 01:00 AM
i would imagine your calipers are sticking cause increased friction and increased wear i had almost the same exact problem with mine. i changed the calipers and added brake grease to where its needed and havent had this problem since.
Argon Sep 30, 2007 05:44 AM
when you tighten a wheel..
look up the torque spec...its right at 100 ft pounds.
then go criss-cross as you tighten...the nut at 12;oo.....then one at 4;00,etc...
MOSTROTORS GET WARPED DUE TO IMPROPER TORQUE.
Dealers have torque sticks that go on the impacts...that only tighten to a set amount.
most tire stores have maroons who overtighten
