-   -   1997 Sierra replacing door speakers/removing door panel? (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/1997-sierra-replacing-door-speakers-removing-door-panel-10876/)
rdowner22 Aug 2, 2009 08:46 PM
i got the two screws in the arm rest, then i removed the triangle piece in the corner and now i don't know what to do from here. i don't want to like snap any clips off. From what I've researched, you are supposed to push up towards the sky to get it off? please help (trying to save money from them dealers)
Mr_Shamrock Aug 2, 2009 09:18 PM
You need to remove the door lock & window switch panel and then it pulls straight off (not up). There are going to be a number of push clips that are a pain in the butt and you will probably break a couple, but they are sold at most auto parts stores. Good Luck!
rdowner22 Aug 2, 2009 09:32 PM
so i need to pull off the handle/lock part and the crank window handle? It doesn't just pull off im pretty sure, then you pull up after that?
RUFFNECK4LYFE Aug 2, 2009 10:52 PM
There is 1 screw on the very bottom towards the front.
rdowner22 Aug 2, 2009 11:24 PM
so there is one more screw im missing? what do you mean towards the front
RUFFNECK4LYFE Aug 2, 2009 11:45 PM
Yes sir friend. Very bottom of panel towards the front of the whole thing. Run your hand on the bottom of the panel and you will feel the contour of it.
rdowner22 Aug 2, 2009 11:59 PM
so then once from there i can pull up, because i dont see a way to take off the handle and the window crank
Mr_Shamrock Aug 3, 2009 06:31 AM
1 Attachment(s)
The window crank (sorry I asumed you had power windows) comes off by removing a c-clip from behind it. It can be a little tricky to get out without the right tool, but you can do it. It slides out side ways. Here is a picture of it...
Attachment 2865
Without the tool you will need to get something flat and slide it behind the crank to remove the clip. The tool that is made to do this job is available at you local auto parts store and is fairly cheap...
http://tbn0.google.com/images?q=tbn:...s4/4067770.jpg
There are some variations, but that is the general look of them.
Good Luck!
RUFFNECK4LYFE Aug 3, 2009 10:21 AM
Yeah what Shamrock is talking bout, I got those universal pick's. A pack of like 4 of them where the tips have different angles. Those are the best. When you do take em off, use a rag on top like you about to open a champagne bottle. That clip will shoot off fast and could hit your eye or off somewhere where you cant find it. They are like 15 bucks a piece at the dealer too.
rdowner22 Aug 3, 2009 10:25 AM
sorry for all extra questions, so do i now have to still take off the door handle piece?
(should i get pictures for you if it helps?)
