1997 Z71 transmission or transfer case failure
My truck is broke down and I don't have a lot of money to fix it, so I was wondering if anyone had any idea what might be wrong with it.
I had just pulled out on the highway and when the truck shifted into 2nd, I heard a very loud bang and a sound like I had dropped the driveshaft. I coasted into a parking lot and looked underneath. Everything looked okay, I decided to park it and call for someone to come get me. When I put it in reverse, it made a grinding noise and wouldn't go into reverse. I got someone to pull it a mile to my house and it made the popping and dragging noise while it was in neutral. If I put it in reverse, it sounds exactly like trying to put a manual transmission in reverse without pressing the clutch. I'm positive it's either the transmission (4l60e) or the transfer case, which is a push button one. The symptoms: It will go in drive, but it makes a popping/scraping sound. I have no reverse, and it makes a loud gear grinding sound as long as it's in reverse. Whatever it is, it isn't good :(. Anyone have any ideas on what might have broke? |
Check your driveshaft!! The rear one. If it is good then drop ur tranny pan and look for metal shavings. Drain it into a clean yellow tub so you can see all the fluid.
More 4L60E woes! Sorry to say it sounds like a tranny issue. If you have to rebuild it there are a few upgrades that should be made. Let us know what you find.
| All times are GMT -5. The time now is 08:41 AM. |
