1999 5.3 liter silverado
I have been having a problem with my silverado and I was wondering if anyone could shed some light. When I first dtart my truck in the morning, it stumbles and misses really bad for the first minute or two and then smooths out and runs well. I have been getting an intermittent code saying bank one and two are lean. Fuel pressure is around 48psi at idle. could this be a fuel pressure regulator??
Thanks!
Thanks!
sounds as if not getting enough fuel when cold. Needs to run rich at first till engine warms then adjust. I do not know which sensors could be bad as there are so many, but someone here will probably know.
Also welcome to the forum.
Hello...I had a similar problem with my 2002,5.3L. Main problem was a weak battery...cold morning starting pulled the voltage down for a bit until it recharged. Ran fine the rest of the day even after letting it sit for hours at -20C.
I understand GM's have problems with their intake manifolds leaking as well, which causes the same problem. Pouring water on the Intake manifold while running rough will usually smooth out the idle...
Hope this is of some help.
Barry
Barry
O2 Sensor Info/Testing
O2 Sensor Testing
If the O2 sensor tests out all right, then I'd start exploring options in the fuel and intake system.
Todd0060
Mar 23, 2026 06:16 AM
Ratherbdriving
Silverado/Sierra FAQs
11
Feb 23, 2011 07:30 AM
carl
Jul 23, 2008 01:02 PM
jaybob314
16
Oct 16, 2007 07:31 AM
