1999 Silverado hesitation
Old Nov 1, 2020 | 10:09 PM
Greenthumb's Avatar
Default 1999 Silverado hesitation
Hello all.
I have a 1999 Silverado 1500 4x4 wi the 5.3LS. I often (but not always) experience a hesitation after first starting it warm or cold. Starts up perfectly always, but once you get underway it’s like it’s starving for fuel. Once this passes (+- 15-20 seconds), truck runs perfect until I shut it down the next time. Dirty MAF, fuel pressure regulator or?? The puzzling part is once the hesitation clears it runs beautifully
Old Nov 6, 2020 | 07:10 AM
chem_man's Avatar
Have you scanned for DTC codes? If not, do that first and report what they are.
Next, check your fuel pump pressure and then the operation of your fuel pressure regulator. Fuel pressure regulator can also be tested by hooking up a section of vacuum line to it and then sucking on it to see if it holds vacuum. If you unplug the vacuum line from the fuel pressure regulator and gas pours out, no need to test it as it's toast.
javier3276
Dec 19, 2011 04:55 PM
robertbassin5
29
Dec 3, 2010 11:39 AM
Gotechslack
Mar 23, 2010 02:52 PM
noslocars
Nov 12, 2009 06:10 PM
bandit0321
Jan 17, 2007 03:23 AM
