2000 Chevy REAR wheel bearing replacement?
Old Jun 14, 2008 | 12:00 PM
fzr1000t's Avatar
Default 2000 Chevy REAR wheel bearing replacement?
Hiya Folks,
I am getting ready to do a REAR wheel bearing replacement, on my 2000 Chevy SilveradoZ71 4X4. From what I have been able to gather, the front is a hub replacement, the rear is a bearing. Can anyone provide me some info on how to? Do I need to remove the axel?
Thanks in advance for your help
Cristian
Old Jun 15, 2008 | 07:03 AM
Argon's Avatar
Default RE: 2000 Chevy REAR wheel bearing replacement?
I have no clue of your mechanical knowledge/tools,but that is not an easy job...messing around inside the rear end is tricky..plus a few special tools needed.
Old Jun 15, 2008 | 03:39 PM
mi.bowtie's Avatar
Why? If it ain'tbroke don't fix it. Rear axle bearings don't go bad very often, unless you hammer your truck.
Old Jun 16, 2008 | 08:55 AM
fzr1000t's Avatar
"Why? If it ain'tbroke don't fix it. Rear axle bearings don't go bad very often, unless you hammer your truck. "
Well... I did kind of do some offroading that seems to have caused some damage to the bearing... So ya I kind of hammered it
Any info would help.
Old Jun 16, 2008 | 04:05 PM
demobud's Avatar
Front bearing hubs are pretty easy since they are a single unit; the rear is just he bearing which has to be pressed out of the hub and then the new bearing presed back in. For my money and time I would take it to a local shop, unless you have a press etc.
Old Jun 17, 2008 | 07:09 PM
fzr1000t's Avatar
Thanks, I was hoping to get away cheap on this one, but I think I am convinced Gonna take it to the shop.
Old Jun 17, 2008 | 07:26 PM
1985Chevy's Avatar
Don't worry man I feel your pain. My rear bearing is so bad oil is leaking all over the driveway from it. But the problem is that we were in the process of changing it. We got as far as taking the pin out of the rear diff. so we could take the axle out, well we found out that the screw holding the pin in, was broke in half. We cant get it out so now we got to get a new back axle. =] which is good for me, im not paying for it, lol my dad is.
Old Jun 20, 2008 | 12:40 PM
fzr1000t's Avatar
I think we may be talking about two different things, my rear WHEEL bearing is bad. I would never consider trying to do anything in the rear end I am not that good!
Old Jun 20, 2008 | 05:11 PM
Argon's Avatar
YOU have to inside the rear end to release the axle,so you can slide the axle out to change the bearing.
GLS0628
Oct 9, 2014 07:44 PM
Mox
Mar 30, 2011 10:48 AM
Wheelgunner
Jul 12, 2010 10:55 PM
HAL9000
Aug 31, 2009 02:19 PM
ddk114
Jan 25, 2009 01:19 AM
