-   -   2001 Gmc sierra 3500/ int low fuel press. (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/2001-gmc-sierra-3500-int-low-fuel-press-6987/)
Carbuff71 Apr 21, 2008 08:03 AM
This one has got me puzzled,6.0 litre efi ,had to be towed home,would start but not enough power to move,checked fuel press.20-23 psi with or without regulator vaccum line on,dual tanks,pumps were replaced at dealer 2 years ago,replaced filter,no improvement.
Argon Apr 21, 2008 09:17 AM
RE: 2001 Gmc sierra 3500/ int low fuel press.
PUMP IS BAD...only 1 pump makes psi to send to the engine...the aux pump just movesfuelfrom tank to tank
Carbuff71 Apr 24, 2008 07:50 PM
Thanks,problem solved,pump was bad sock was also full of mud and rust,found cut filler neck vent hose behind rear tires,also rusted fuel lines from front tank to fuel filter.WOW not a cheap fix.
