2001 GMC sierra signal switch replacement instructions.
im looking for or where could i get instructions (without having to buy) on how to replace my turn signal switch for my 2001 GMC pickup, 3/4 ton, 4wd automatic..any help or direction or information would be greatly appreciated!
Pull the steering wheel and lock plate,take the 3 screws off the assembly,unplug the harness at bottom,pull the wiring out, to replace just run a wire coat hanger through the column from the bottom, and hook your new wiring to it to pull it through the column, replace srcews and wheel,hook up wiring,you're done.
| All times are GMT -5. The time now is 10:37 AM. |
