-   -   2001 silverado drive train troubles (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/2001-silverado-drive-train-troubles-8192/)
wrimar61 Oct 15, 2008 07:34 PM
hi i'm new to the forums and have some maintainance question for my 2002 Silverado Ext Cab 4.8L V8 Auto 4x4
When I even ease in drive sometimes i will hear a creeking/cracking sound
and when I go from P to D or change gears at all for that matter in will jerk and sound like a slap, also while moving when the truck swithes gears i will get a little jerk.
common sense tells me it seems like it time for a new tranny with roughly 75k miles on it
but was wondering it may be anything else before I spend the cash on a new one.
Also, I wanted to change out the U joints to see if that would fix it and after spending around 4hrs and not getting any caps off the old U joints i gave up, any suggestion or tips
MrLM7 Oct 15, 2008 07:50 PM
RE: 2001 silverado drive train troubles
U joints...
NewVagus Oct 15, 2008 09:06 PM
How many miles? It could be several things. There are things to look at with high mileage vs lower. If you are checking the u-joints remember to jack up the rear end to check.
chuck4379 Oct 23, 2008 07:17 PM
defintley check your u-joints first. cheap fix in the garage, expensive fix if it lets go on the freeway.
jcbst12 Oct 24, 2008 07:47 AM
I have the same thing going on with mine, especially when shifting from drive to reverse. I also get a slight vibration between 60-70 MPH. It should be the U-joints.
Hey, how much of a bitch is it to remove the u-joint closest to the yoke? It looks like a bitch to get out! Maybe take it to someone with a press?
aja72 Apr 12, 2010 05:44 AM
I also suggest you to check U-joint & gear box first because i think after check this definitely you will know about problems.
