2003 Silverado Fan Problrm
My heater fan only works on speed 3 and up. It will not work on lower speed. Has anyone had this problem?
Thanks, Tom |
RE: 2003 Silverado Fan Problrm
I had a problem similar to this on my 95 Z ended up replacing the fan motor and something else. I cant remember what it was called and it was hard to get to. It had something to do with temprature sensing and it was under the dasn near the fan mounted in the "duct work" of the a/c/heater.
its the a/c resistor MOST LIKELY....but could be the switch...
if the resistor plug is melted,you'll need a resistor and a connector |
its the blower motor resistor its very very commen for those to go bad on any car
Argon
Where is the resistor and connector? |
on the right floorboard....loadred trucks have a panel that hides the a/c box...cheaper truicks do not..
look uynder there...you'll see the round fan motor...left of that is the resistor,with a big plug with about 7 colored wires....unplug that and see if the end is melted |
A buddy of mine's 06' burned to the ground because he didn't fix that melted plug.
Thanx Argon
I'm on a road trip in the Smokies.. will check it out.. when I get home & let ya know how it turns out |
