2004 Sierra: Help!! Can't find the Transfer Case Control Module
Old Jun 6, 2008 | 07:41 PM
  #11
swampdog's Avatar
Default RE: 2004 Sierra: Help!! Can't find the Transfer Case Control Module
eBay special. New in box; still waiting for it to arrive.
Old Jul 11, 2008 | 10:38 AM
  #12
swampdog's Avatar
Here's an update in case anyone is interested. The new encoder motor seems to have fixed the problem - no SERVICE 4WD warningor random shifting of the transfer case since replacing the encoder motor.
Old Jul 11, 2008 | 11:01 AM
  #13
rxsteven's Avatar
Good to here Thanks for the update.
Old Sep 14, 2008 | 11:17 PM
  #14
oldknight68's Avatar
I was wondering how hard it was to replace that motor? I have an 04 and just recently started having the exact problems you were decribing.
Old Jun 30, 2012 | 02:44 PM
  #15
azjej's Avatar
This is an old thread but it did me some good. I read several places that the TCCM was behind the light switch. I found mine factory clipped and tie wraped fwd of a box that is behind the OBDII plug. NO dash removal required. I replaced the unit with a used one. THe jury is still out if this will fix the problem. looks good. If I have problem I will look at the next cheapest part, likly the sensor.
Have fun
JJ
2004 avalanche silverado
Old Sep 14, 2013 | 12:24 PM
  #16
waltered0201's Avatar
just went through the same thing with my 2003 Silverado. not where it says it is in the Haynes repair manual. It is located right above the emergency brake pedal. have to get it from behind. It snaps out. tight fit with the wires and cable running past it.
Old Jan 13, 2017 | 10:15 AM
  #17
shermanjim's Avatar
have same issue ...cant find it. after reading forums for a month I think i should just visit the overcharging dealer ...again!!! Ive had to put in five transfer cases in my 05 yukon...236,000 miles. cant afford a new car and cant afford to keep this one on the road!!!
Macauboy
Apr 18, 2014 01:36 PM
sktyrhrtout
Dec 14, 2011 05:04 AM
shop2011
Sep 8, 2011 12:40 PM
getstuck91
Aug 27, 2010 07:21 PM
KJHansen02Sub
Oct 16, 2007 06:05 PM
