-   -   2005 GMC Sierra power steering problem (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/2005-gmc-sierra-power-steering-problem-20597/)
Br2710 Feb 3, 2015 06:39 PM
In October I had the power steering pump replaced due to the reservoir had a crack that was leaking. I changed the high pressure line also. I also changed the steering gear box due to a catch in it. I bought all the parts from advanced auto. The first pump lasted 4 weeks, it just stopped working. The next pump blew the return line off twice. I changed that pump and the gear box just to eliminate that as a problem. This pump lasted a couple of weeks then it blew the return line off again twice. I replaced the pump 3 weeks ago then, this morning I remotely started the truck and when I went out 5 minutes later it had blown off the return line. I went to autozone and got a pump from a different manufacture. I installed it and it blew the return line off. I have no idea what to do now. I blew out the cooler with air and it seemed not to be blocked. Thanks for any help
primem Feb 3, 2015 07:08 PM
Are you using the original spring clamp on the return line? Over time they get weak. Use a gear type hose clamp. If you have a gear clamp on it, you will need a power steering analyzer to check pressures/restrictions/blockages.
Br2710 Feb 3, 2015 07:14 PM
I actually did install a gear type hose clamp. I drive it again tomorrow and see if the new clamp holds. Thank you for your help
