2006 Duramax P0401 & P0402 DTC Code
Old May 13, 2009 | 07:19 PM
timw60's Avatar
Exclamation 2006 Duramax P0401 & P0402 DTC Code
My check engine light came on today so I put my Bully Dog tuner on and codes P0401 and P0403 came up. From what I have found out it is something related to the EGR. If so does it mean that it's pluged? It has 32750 miles on it.
Old May 13, 2009 | 08:23 PM
Did some research and these are the fixes I have come up with:
-Check the voltage at the DPFE sensor both at idle and when the EGR is open
-Replace DPFE sensor
  • Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's & DPFE voltage. There should be a noticable difference in RPM's with the EGR open
  • Clean out the EGR valve and/or tubing to remove deposits
  • Check the voltage at the DPFE, compare to specified values (refer to a repair manual for your specific model)
  • Replace the DPFE sensor (with a good quality / OEM one)
  • Replace the EGR valve
I don't know what all this means, but maybe you do... :/
Old May 14, 2009 | 06:46 AM
timw60's Avatar
Thanks Kevin.
basswall
Apr 24, 2011 04:23 PM
GMCSierraFan
Feb 13, 2010 10:03 AM
chefbutthead
Silverado/Sierra FAQs
Nov 16, 2008 02:36 PM
Chevyalltheway
Aug 29, 2008 10:16 PM
devtaps
8
Aug 24, 2007 06:03 PM
