-   -   2007 Silverado 1500 oil filter? (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/2007-silverado-1500-oil-filter-4781/)
dk1ben Oct 14, 2007 11:54 AM
Ok so I have a new 2007 Silverado v8 5.3 crew cab 2wd. with active fuel management.
My father in law has suggested using Mobil1 oil and ACDelco filter. I dont question the oil choice. However shouldnt I use I higher quality filter. He claims that I much use ACDelco filter not to mess up my warrenty. Any thoughts?
Tweaker Oct 14, 2007 01:54 PM
RE: 2007 Silverado 1500 oil filter?
As long as the filter meets OEM demands then its fine. :) Ive been using Hastings filters for awhile and havent had a problem with the cheapies just gotta change them at their time.
Argon Oct 14, 2007 02:53 PM
A/c delco is best,cuz its designed for that engine..not just one that "fits"...
some others are probably ok...but make sure it has a check valve like the Delco,to keep the oil from draining back overnight
JohnAdamsR Oct 14, 2007 09:46 PM
Argon may be right but if you do get the Mobil1 filter it should be good. Those are some of the best (and most expensive) filters u can find.
BlackHorse99 Oct 14, 2007 10:58 PM
a lot of people come into gm and get theire oil changed with mobil1, and we put ac delco filters on, 2007's run a pf48, in case you wanna know
jcbst12 Oct 15, 2007 12:10 PM
At Advance we had a standard advance filter that was cut in half along with a FRAM Tough Guard filter that was cut in half, they were identical in design. The medium (filter material) might have been different, however. The Advance filter was only a couple of bucks and about 1/3 of the price of the FRAM Tough Guard. I was told to steer away from the basic FRAM filters and generic filters. I usually use Mobil1 or ACDelco.
