-   -   2008 4.8l engine noise (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/2008-4-8l-engine-noise-18114/)
RUFFNECK4LYFE Jan 5, 2012 10:54 AM
Yeah im goin with lifter too. Really the only way to see is take stuff apart(which I know you dont wanna do). Pulling the cam could show some wear on the lobe the lifter is rolling on. Like I said I know you dont wanna do any of this stuff. My 01 has had a lifter tappin sound since I got it and no problems. I have even put in cams in it and its still there so this may fall under the "Phantom GM Knock" issue that has been around since they came out with the Gen III motors.
Just watch your oil pressure close to see if it fluctuates, this will be the first sign of mechanical failure.
01liftedsilverado Jan 5, 2012 11:16 AM
i have a 01 with a bad roller rocker have had the ticking noise an gm knock for a while now no issues still plenty of power just let it be do your oil changes an services as needed keep an eye on your oil pressure hope this helps -pat
scubiesteve Jan 5, 2012 01:09 PM
the problem is, with the new chevy's at least my 08 there is no oil pressure gauge just a low oil pressure idiot light. I even hooked up my buddies OBDII reader and we have every reading but oil pressure. So this scares me, I'm thinking of making an appointment with the GM dealership but it's so quiet now they will charge me an $85 diagnostic fee because they won't hear it. I can hear it but I know what I'm listening for.
01liftedsilverado Jan 5, 2012 02:08 PM
bring it to a dealership an have them go threw it u dont want to end up like my buddy did he just had to rebuild his engine in his 03 duramax b/c of a blown headgasket that was overlooked it may be costly if u dont assess the situation now just my 2 cents buddy
Razoo Jan 6, 2012 05:30 PM
Originally Posted by scubiesteve (Post 73930)
the problem is, with the new chevy's at least my 08 there is no oil pressure gauge just a low oil pressure idiot light...
Really? No Oil Pressure gauge in your 2008? My 2008 Sierra has an O/P gauge in it. I'm surrised the Chevy doesn't.
scubiesteve Jan 6, 2012 09:22 PM
The truck is at the dealer and I should hear something by Monday or Tuesday, hopefully.
scubiesteve Jan 6, 2012 10:07 PM
http://www.shopautoweek.com/content/...ns/636.477.png
This is what my instrument cluster looks like, just fuel, coolant temp, mph, and tach.
01liftedsilverado Jan 7, 2012 10:27 AM
even my truck has a oil pressure gauge an mine is a 01 base model 1500 it even has tow/haul mode as well,im with razoo on this hope to get an update as to whats wrong with it soon good luck
scubiesteve Jan 7, 2012 12:32 PM
So they just called and the verdict is bad valves. So they are going to rebuild the engine under factory warranty. I'm curious if they find more things wrong when they start tearing into it. But they are also replacing my driver window regulator and driver rear door lock actuator all under my extended warranty. They wont start till Monday though when the parts come in. My 1500 has a tow/haul mode as well. I'm trying to see if the 6 gauge cluster is a plug and play cluster in my truck. If so I'll be putting that in for assurance.
Razoo Jan 8, 2012 07:00 AM
Well, good luck with the rebuild, and thank goodness for warranties!
Did you buy the truck new?
