2021 Sierra 1500 - squeals when decelerating between 1000 and 2000 rpm
Old Jan 4, 2023 | 11:48 AM
repliconus's Avatar
Question 2021 Sierra 1500 - squeals when decelerating between 1000 and 2000 rpm
Hi All - I'm new to this forum and was hoping someone out there might be able to help explain what's going on with my truck. I'm hearing a high pitched "squeal" when my truck is decelerating. My truck is a 2021 GMC Sierra 1500 w/ 3L Duramax i6 diesel engine and w/ automatic transmission (not sure of the transmission model). So far I've noticed the noise happens under the following conditions:
  • after the engine has reached running temp
  • only when the truck is breaking or "coasting" - by coasting I mean foot off gas but still in gear, not coasting in neutral
  • only seems to happen (or at least only seems to be audible in the cab) between 1000 and 2000 RPM - it's loudest when it's closer to 2000 RPM and is no longer audible when it drops below 1000 RPM - doesn't seem to matter which gear I'm in
  • the noise cuts out when I press on the accelerator - even if I just tap the "gas pedal" the noise will stop for a brief instant before it starts again
  • it doesn't seem to happen when I'm using cruise control
  • it only seems to happen when the truck is in gear - in other words it doesn't happen if I just rev the engine above 2000 RPM and let it come back down
I'm guessing it has something to do with my automatic transmission, maybe something with the clutch(es), but I was hoping to get a few more insights before I take it to the dealership.
Thanks in advance.
-Scott
Danube
Jan 4, 2022 05:45 AM
gdean7
May 31, 2021 11:19 PM
Modball Team
Jun 21, 2011 09:45 AM
GMC RP
Mar 11, 2007 08:48 PM
