-   -   4 wheel drive (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/4-wheel-drive-4953/)
BigRandy95 Oct 28, 2007 08:06 PM
4 wheel drive
hey guys i have a question. is there any way i can make my 1997 chevy 1500 extended cab 2 wheel drive a 4wheel drive? someone told me the other day there is a kit or something like that. is there any thay anyone knows of?
racethisz71 Oct 28, 2007 08:33 PM
RE: 4 wheel drive
it will be cheaper to sell your truck and buy a 4wd one. you will need a transfercase, drive shaft and a front axel which will cost a good amount of money
BigRandy95 Oct 28, 2007 08:36 PM
RE: 4 wheel drive
how much are we talking? over a grand?
jcbst12 Oct 29, 2007 08:15 AM
RE: 4 wheel drive
It would be much easier to do it like Argon said and just buy one. If you had your heart set on it and you still want your truck to be a 4X4, you could buy a 4X4 with the same wheelbase and swap the bodies (and engines if you wanted to), then put the old stuff on your old chassis and sell it. You could rip apart your current truck and replace it all with 4wd stuff but you looking at way too much fabrication and labor, I mean you'd be working on it for an eternity to get it all working properly. Plus you would be replacing the entire front end of the truck anyways so just swap bodies or just trade yours.
04BLKCHEVY Oct 29, 2007 08:52 AM
RE: 4 wheel drive
Go to offraodunlimited.com and they have some kits.
BigRandy95 Oct 29, 2007 09:06 AM
RE: 4 wheel drive
ok appriciate the input. ill see what i do
jcbst12 Oct 30, 2007 11:31 AM
RE: 4 wheel drive
Solid axle kits would work so at least you could lift it real easy.
BigRandy95 Oct 30, 2007 08:47 PM
RE: 4 wheel drive
how much would i be looking at to do all this?
jcbst12 Oct 31, 2007 07:43 AM
RE: 4 wheel drive
With a kit? No idea. The straight axle kits don't come with the axle (I don't think), but you can get one from a junkyard pretty cheap.
04BLKCHEVY Oct 31, 2007 08:39 AM
RE: 4 wheel drive
It all depends on what type of axle you want. It is not cheap. There is a lot of fabrication to do. You need to get a transfer case and a tranny for a 4x4. Are you looking for a straight axel or doing the IFS. Just check out the prices of the kits at offraodunlimited and give them a call. They will give you an estimate. They have done a lot of conversions.
