4l60e
Old Jan 29, 2011 | 09:25 AM
housefire02's Avatar
Default 4l60e
. I have 96 z71, my old trans went out bought a rebuilt one and put it in.. Here is the problem it will not shift into o/d on a great clear day. But let it be raining or the streets be wet and it will go into o/d.. It may stay in o/d and do fine or it may jump in and out.. Can anyone point me to a starting point..or give a idea where to start
Old Jan 31, 2011 | 12:32 AM
chrisbmo2000's Avatar
Did you replace the torque convertor?????? that is where "lock up" happens....if you didnt then you wasted your time...also check all wires going to the tranny for chaffing or cuts.
Old Jan 31, 2011 | 05:46 PM
yes i replaced the torque convertor..I have traced wiring until i,m blue in the face.. One of these days i will find the problem
Old Jan 31, 2011 | 06:35 PM
SlimJim's Avatar
I would just about bet it's an electrical connection breaking down somewhere. Often wet conditions may cause you to lose your connection but it could cause you to create one also. I would pull every plug apart and check for bent or pushed back pins, clean with contact cleaner and seal it up. You may want to put dielectric grease in the ones exposed to the weather. Good luck.
MrLM7
12
Feb 6, 2009 07:44 AM
gmworker
Aug 29, 2008 08:26 PM
72charger
Jul 13, 2007 04:04 PM
gas guzzlin 4x4
May 1, 2007 04:08 PM
98ChevyLuv
Jan 16, 2006 10:16 PM
