4wd noise?
Old Dec 14, 2007 | 09:15 AM
jcbst12's Avatar
Default 4wd noise?
I know I could just be paraniod, but when my truck is in 4wd, and I give it some pedal, it makes a roaring sound. Not that bad tho. It stops when you lay off the pedal. It makes the floor rumble very slightly. My 91' GMC did this too and I never had a problem with it. I guess maybe because my 99' is no much quieter, I notice it more. Should I be concered at all?
Note: Front diff fluid and transfer case fluid were replaced already.
Old Dec 14, 2007 | 10:04 AM
Bebop's Avatar
Default RE: 4wd noise?
If I am thinking the same as you then my truck does the same thing. I really don't think its anything to be worried about. If your that worried just keep an eye out for leaks or if the noise gets any worse or starts happening all the time.
Old Dec 14, 2007 | 11:30 AM
04BLKCHEVY's Avatar
Check all your bolts to your transfer case and front diff. I had my front diff loose once. I was missing two bolts. I was surprised it didnt fall out. The noise is the transfer case just doin its job.
Old Dec 14, 2007 | 11:38 AM
jcbst12's Avatar
Thats what I figured, just thought I'd ask. I was worried I'd say that and everyone would be like "Oh it should be silent" or something. Everything looks intact, I was more worried about bearings or something. Ok, thanks guys.
05 GMC
Sep 13, 2012 05:16 PM
JoeYukon79
Mar 14, 2012 06:48 PM
05 chevy 2500hd
Apr 3, 2011 11:50 PM
xtremenorthwest
Oct 3, 2007 08:25 PM
pclosse
Aug 13, 2005 10:52 AM
