4x4 problem ?
when ign.on,or running at dead stop,
my truck is in 2wd by default,when i push the button for 4wd high i can here it engage and the light comes on as it should, but when i push the 4 wd low button i can not here anything, and the light flash's for about 30 sec.and then goes to 4wd high, no codes on scan, 03 sierra, ext.cab 5.3 thanks for any help |
RE: 4x4 problem ?
Do you have the transmission in neutral when attempting to engage 4 low? 4 high can be done on the fly, but you likely have to stopped in neutral to go 4 low. Did it work previously?
RE: 4x4 problem ?
dead stop in park,i don't knowif it worked when i bought
it a couple of weeks ago, i know i tested auto 4w, 2whigh,and 4 high, i might have missed pushing the 4 low, talking to the salesman.i bought a lifetime drivetrain warrenty, but it take's 4 mo's or 4000,miles before it will take effect,if not using it will not hurt the truck, then i will take it in afyer the warrenty kicks in. i was just currious as to why i don't here anything when i push the 4lo button |
RE: 4x4 problem ?
i have an 01 sierra z71. its been a while but i am pretty sure the truck needs to be in neutral and rolling slowly and then punch four low to get it in that gear.
hope this helps. |
RE: 4x4 problem ?
yelp that worked
