-   -   4X4 wont engage (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/4x4-wont-engage-8669/)
bjf1280 Dec 20, 2008 01:11 PM
4X4 wont engage
My 1998 Z71 won't engage when I try to put in to 4 wheel. About 1 month ago as I was coming off the beach in 4H I could only get it back in to 4L. Had to drive home pretty slow but when I got home it smelled like something was burning.Finaly got it back to 2H by hitting a pot hole while pushing the button on the dash. Tried again today in the snow and it won't engage at all, just clicks and bangs like it's going in but the hubs dont seem to lock. ??????
Rockstar112 Dec 20, 2008 04:36 PM
RE: 4X4 wont engage
Check the upper control arms my buddies truck broke the bearing in his truck on the right side a little while back. My truck has the similar problem so I have to be rolling but not on the gas..... check the control arms that might be the problem
bjf1280 Dec 20, 2008 07:14 PM
RE: 4X4 wont engage
I will, thanks.
wickedlester Dec 23, 2008 03:35 PM
RE: 4X4 wont engage
I have a similar problem in my 00 Z-71, but its because the push-button switch is on its way out. The 'service 4wd' light will come on, but most of the time it will work if you give it a good thrashing.
A friend of mine had the same problem and had to replace the switch. I hope this isn't the problem, one of these will set you back $120.
bjf1280 Dec 24, 2008 08:17 AM
RE: 4X4 wont engage
hopefully thats all it is, the control arms are alot more expensive. will a diagnostic check by a mech. send a code?
