5.3 engine miss
Old May 10, 2009 | 02:36 PM
Ktowner's Avatar
Default 5.3 engine miss
I have a 2000 Silverado 5.3, A/T with 130K miles. I am noticing a slight miss at idle when dropped into gear. If you raise the RPM slightly the miss goes away. I have access to a SNAP ON Motis but have had very little training, mainly what I have taught myself. The miss does not set a code. At idle with Motis you can see a 20 to 30 count misfire per 100 seconds cycle, half occurring on number 5 cylinder. The others are random between the other cylinders. I have replaced spark plugs and fuel filter. I have not tried plug wires yet. What else could be causing this?
Old May 10, 2009 | 04:30 PM
Have you cleaned the throttle body? They are notorious for gumming up and causing a miss. I had one not too long ago that would shut off from such an irratic idle. A can of throttle body cleaner and it ran like new again. If not an injector may be the culprit.
Old May 10, 2009 | 11:50 PM
chrisbmo2000's Avatar
there are some on this forum who have had problems with lifters....and a bad lifter will cause enough of a miss to "notice" but not set a code that being said I would try wires first and clean the throttle body
Old May 19, 2009 | 12:40 AM
RUFFNECK4LYFE's Avatar
Sounds like a clogged Injector. Check fuel pressure with a guage.
Old Jun 7, 2009 | 02:14 PM
bambam911's Avatar
Default throttle body
My 2000 gmc sierra 1500 just came from the shop because of a slight miss. I had the plugs replaced and it still has a slight miss. How do I clean the throttle body. The truck always starts fine the first time but subsequent starts take a crank or two. It also hesitates some times when I take off. Should I change the throttle position sensor. I am stumped but tired of paying 80 bucks for diagnosis that dont tell me ........ please help
ps- how do I change my idler arm. it is worn
Old Jun 7, 2009 | 02:26 PM
DamnYankee's Avatar
Fuel pressure won't reveal a bad injector. Pressure is obtained before injectors.
Check your wires, make sure you don't have a broken boot or cracked jacket or something. Also check your fuel pressure regulator.
Old Jun 7, 2009 | 04:41 PM
I was only suggesting to check fuel pressure. I was stating my opinion a to what I thought might be the problem. Checking fuel pressure will rule out whether it is the fuel pressure reugaltor, or fuel filter, or fuel pump, or a wiring problem. Which then can suggest if it is a fuel problem, then narrow it down to a possible clogged injector. Shoulda elaborated more my fault.
Old Jun 7, 2009 | 07:23 PM
DamnYankee's Avatar
I wasn't trying to sound like a jerk, sorry.
All good ideas.
valveguy
Silverado/Sierra FAQs
Mar 24, 2011 05:44 PM
Meternerd
Mar 6, 2010 11:01 AM
2rustyGMC93
Jan 18, 2008 05:08 PM
bizkit132
Apr 30, 2007 09:54 PM
rotndawg
Nov 26, 2005 10:34 AM
