-   -   5.3 Engine Noise (https://www.truckforums.com/forum/chevy-silverado-gmc-sierra-forum-11/5-3-engine-noise-8920/)
Ktowner Jan 22, 2009 06:28 PM
5.3 Engine Noise
I have an engine noise in my recently purchased used 2000 Chevy Silverado. I have the 5.3 engine with 126,000 miles. When first started after setting overnight or all day while at work, I can hear a dull knock for about 10 to 15 seconds. If you drop it into gear, (automatic) and leave at idle, it sounds very much like a diesel engine knock. It carries 60 psi oil pressure, (dash gauge) from the get go. I never here the noise any other time. The engine runs good, doesn't smokeand doesn't seem to use oil. Could I possibly have a lifter that is bleeding down? If so does anyone know of any oil additive that might solve this problem or is it best to bite the bullet and replace the lifters.
rxsteven Jan 22, 2009 09:41 PM
RE: 5.3 Engine Noise
We all got that! mine dose it untill it warms up. I ran some Sea Foam thew it and it went away for about 2 weeks and came back.
bfg112 Jan 23, 2009 08:51 AM
Sure do. Mine does it. If you rev the engine once or twice it will usually go away. I guess that throws the oill around enought to quiet it down. If anybody has a fix though, I'd like to hear it.
Buck40y Jan 23, 2009 10:35 AM
My 1999 does the same. It didn't start until about 100K. It sounds like a lifter tick. My GM mechanic assures me that it is normal and is not causing damage. We'll see. I have 163K now.
black2k1z71 Jan 24, 2009 01:14 PM
mine has done it since i bought it around 118,000. there are a lot of articles on this if you google it or even search the forum. it's piston slap due to gm changing the way their assembly line manufactures pistons to fit individual pistons. they used to match each piston to each cylinder, but eventually they just started mass producing pistons that were the exact same size....for some reason they don't all match up exact with the cylinders they are placed into because of this and a lot of our trucks get piston slap because of it. after enough oil gets to the top of the engine it stops the noise...gm says it's not a big deal.
jcormier89 Jan 24, 2009 02:37 PM
if it only happens when the engine is cold thats probably just your oil being circulated throughout the engine...all chevys are like that
on a side note, dont drive until that knocking stops, you dont wanna push your engine till the oil is completely cicrulated
bfg112 Jan 26, 2009 09:00 AM
ORIGINAL: black2k1z71
Where did you read that? That doesn't even make sense. If that were the case, how would you ever buy a set of pistons to rebuild a motor? Do you have any idea how long it would take to produce motors if you had to custom make every piston for a specific cylinder? Of course they're all the same size.
sullyda Apr 8, 2009 09:27 PM
When rebuilding a motor, it's best to measure each piston and then bore the cylinder to the piston size to be sure you have the correct cylinder wall clearance. Pistons do vary slightly in size.
98white5.0 Apr 8, 2009 09:35 PM
The thing that happened is the tolerances got sloppy and broader.
