5.3L /LS1 questions
Old Jul 15, 2007 | 11:56 PM
emmerich5.3's Avatar
Default 5.3L /LS1 questions
I have a 5.3L 2wd silverado. I was wondering if anybody knows what the compatabilies are between the 5.3 and the LS1/LS6's are. For example, will the LS6 intake manifold will fit on the 5.3. And what are the differences as far as cam, heads, etc...
Old Jul 16, 2007 | 08:47 PM
BlackHorse99's Avatar
Default RE: 5.3L /LS1 questions
as far as i can tell, they are the same, i was looking at putting a z06 cam in my 5.3, coulda been killer...
Old Jul 18, 2007 | 10:10 PM
MrLM7's Avatar
The intake manifold will fit, but you have to do some modifications to the bracket for the throttle cable... Everything else is direct fit...
Old Jul 18, 2007 | 11:12 PM
big red's Avatar
They will fit like MrLM7 said but if you buy a used one make sure it is an LS6 manifold. The LS1 and the LS6 manifolds lok very similar. The LS6 has a flat low-slung floor and the LS1 floor has a double swoop in it where itisdeeper at the center. Also there is a book called "How to build high performance chevy ls1/ls6 v-8's" it is a great book and it tells you which parts are interchangeable and which ones are the bestfor the different egines. Here is a link
http://www.amazon.com/How-Build-High-Performance-Chevy-V-8s/dp/1884089844 http://www.amazon.com/How-Build-High-Performance-Chevy-V-8s/dp/1884089844
well worth the $13
korygrandy
19
Jul 17, 2015 09:00 PM
joshcaniglia
Sep 7, 2009 08:17 PM
BigRandy95
Feb 26, 2008 07:11 PM
MrLM7
Aug 13, 2007 10:08 AM
701NN
Aug 3, 2004 06:56 PM
