The plugs on the backside are a possibility I didn't think of. I'll post here what I find. Been to cold around here all the sudden to be doing much. Appreciate the advise
Originally Posted by Dansic
(Post 79106)
Originally Posted by Diesel Dan
(Post 79107)
Where is "here"?
So the oil was coming from the rear of the engine from under the inspection cover?
Nice thing is those engines can be out in around an hour or so. |
Just ting this all up. I know it is belated, but it's an odd occurrence. I have since rebuilt this engine completely as what happened fried the cam, and ALL bearings in the short time it was running in this condition. I had taken the TPI intake off to paint and polish it. During that time, the fuel lines remained loose over the lifter valley. I had forgotten about them. Normally this wouldn't be a cause for concern. But my fuel tank does NOT release built up pressure. (i dont know why) This caused gas to splurge out into the lifter valley, and consequently, into my oil. That in turn caused the oil to reduce its viscosity, and spew out of both the main seals. It was a dumb mistake on my part. The oil should have been replaced anyway, but at the time i was short on cash. I got a new job shortly after and rebuilt the engine. Thankfully, Crane Cams keeps ALL their cam specs from any year they made a custom work. Got my cam, lifters, push rods, bearings and now it purrs. I thank anyone who tried to help!
Wow !!! Who would have thought... Thanks for coming back to update your thread.
Don't be a stranger |
Oooohhhh .... I would have guessed you would have just pushed the lines off to the side or disconnected them before removing the intake. Which would mean that the fuel would have just ran off the intake and down the engine, or evaporated before you got the intake off.
Interesting. So your fuel lines were leaking fuel into the lifter valley for a good week before you started it up? That'll do it ... |
Wow, what a thread! As I was reading it, I was reminded of instances where people mix solvent-type into sealing-type coolant, causing otherwise "sealed" leaks to dissolve and suddenly start hemorraging. In a way, that seems to be what happened, just with your oil.
Glad to hear you're engine is where you want it to be! |
