89 Z71 1500 shortbed
Old Mar 19, 2011 | 09:22 PM
ZMan71's Avatar
Default 89 Z71 1500 shortbed
Can anyone tell me what I should do to my favorite truck so that I could pull a 5000 lb. travel trailer. The truck is stock and I am the only owner. Z71-350hp everything is stock. NEED HELP!
Old Mar 20, 2011 | 06:50 PM
jvp's Avatar
jvp
Member
When you say stock not all trucks are the same?
Some come with Camper or Tow packages included.
So let's assume your truck has not tow package items, and I am going to
also assume that the trailer you are talking about is about 20' long dual axles, with a TW of about 400 lbs.
So let's go shoping:
Trans-cooler
Class IV or V Hitch, 1000 lbs TW 10000 lbs towing
Tekonsha Prodigy P2, electronic brake controller
Wire kit for brake controller
Weight Distributing hitch, look at something like 10000 GTW, 600 lbs TW
Draw Tite Friction Sway Control
7-way wire kit with plug for the truck
The Weight Distributing hitch should bring your truck back to level with the trailer
sitting on the ball, if not you may want to look into some Firestone or Hellwig air springs. One thing to consider with weight distributing hitches is a higher TW rating will also affect the ride quality.
And before you set the trailer on the ball always put on a light coat of clean greese
You can price shop all of these items on the internet, but be ready you are going to spend around $1000
I would also recommend flushing all your fluids for new, trans, oil, radiator, gears, transfer case, and I like synthetic in the gears and engine oil.
These items properly installed should get you down the road safely.
Good Luck & Have Fun
jvp
joelriojas
Vehicles for Sale
Jan 3, 2012 09:28 PM
NastyFusion
General Motors Concepts & Rumors
8
Mar 9, 2011 05:24 PM
makoltd
Dec 13, 2006 08:35 PM
mrhaney
Vehicles for Sale
Aug 27, 2006 10:12 AM
Razz2o4
Vehicles for Sale
Dec 29, 2005 01:32 PM
